Filling gas tank
Tim's23Mav
Timothy
Inkster, Mi
2023 Maverick Hybrid
I have a 23 hybrid I am trying to fill tank from a 5 gallon can, the hose goes in opening, but it just overflows, nothing does into tank. I bought a battery operated filling device but the same thing happened. What do you do if you(God forbid) run out of gas ??
Master Blaster
Master
Toronto
23 Maverick Lariat Hybrid
You can't fill directly from the container. There is an ant-siphon valve in there. Use the provided adapter. It should be in the jack bag or under the rear seat. This has been standard on Fords for 13 years now.
Cancunbadlands
Cancun
Cancun
Use the provided adapter for that matter
ripperAZ
AZ
2022 Mustang MachE 2021 Genesis G90 2032 Mav
As always. RTFM
Read the F@cking manual
It’s right in there under fueling
The part you need is under your back seat
RTFM. Almost everything is in there, including a lot of stuff you don’t need.
Matso
2011 Mustang GT Premium
Incidentally, there are vanes or "fins" inside the adapter filler tube that are designed to provide a smoother flow of fuel and reduce splashback. In my experience with the tapered spout on my can, this design makes those issues worse. I knocked them out with a standard screwdriver and the flow of fuel is now unimpeded and there is zero splashback. If you experience these problems with your particular gas can spout, this modification may correct it.
Randorita
Randy
Mississippi
2021 Toyota RAV4, 2025 Maverick Lariat
RTFM? NO! Ford didn't want me to read it or they would have given me one instead of hiding it in the infotainment system or having me search online for it! I usually sit down and skim through one after getting a new vehicle, but I am not doing that sitting in my truck or reading on my phone. $40k and I don't even get a manual. I expect it with a video game, but not with something as complicated as a new vehicle with all the advanced electronic systems. So, I will wait until I have a problem and the search for an answer.
ripperAZ
AZ
if that’s the case, then you’re also gonna need to know that the manual fuel door release is underneath the wheel well that’s in the manual as well. The manuals are pretty easy to find online ….probably just about as hard as coming here. But here you get Jovial abuse with info..
For some reason this was omitted this in the manual, printed or online. 🤣
The fluid guidance adapter that Ford includes with your Maverick is a dual use product. Keep it handy on long trips, along with a disposable storage receptacle and you can extend your range.
Ford Maverick Filling gas tank IMG_20260516_185105
BillHanna
Cana, Virginia
2024 Maverick XLT, 2020 RAV4, 1975 Corvette Stingray
RTFM is not particularly helpful (and a bit rude). 550+ pages covering every option possible creates a confusing jumble of information. Yes, there is an index for looking up specific options, but if someone can't ask a simple question on this forum, then what is the forum for?
ripperAZ
AZ
lol
RTFM is from a military background
The manuals were not much help
I was just joshin him a lil
And Now he knows where his manual fuel release door is….
stevj
Stev
Pacific Northwest
2024 Hybrid Maverick
I submit that "Lack of knowledge of Ref. A" (a phrase used by the military that means RTFM before asking) is more common than you might think.
So many of the questions posed in this forum would have been rendered unnecessary if reading wasn't so hard.
