2026 Ford Maverick - Passenger Window No Longer Goes Down
Blaine
Midwest
Ford Maverick XL Hybrid 2026
Does anyone else have this issue?
I plan on notifying the dealership when I go in for an oil change.
Blaine
Midwest
Did you hit the power window lock button on the drive side by any chance?
I've tried it with this on and off. I can't open from the passenger front control or the driver control.
Ecorydr
2026 Maverick Lariat AWD
From web:
"If your 2026 Maverick's front passenger window is unresponsive, first check if the window lock-out button on the driver's armrest is accidentally engaged. If that is not the issue, try recalibrating the window's memory or resetting the switch.Try These Quick FixesThe Reset Trick: Using the switch directly on the passenger door, press and hold the button down for 5 seconds. Then, pull the button all the way up and hold it for another 5 seconds. This often clears minor computer or calibration glitches.Switch Jiggling: Sometimes the electrical contacts in the passenger switch get stuck. Try tapping the switch repeatedly while holding it in the "up" or "down" position.Diagnose the IssueCompare Switches: See if the passenger window works from the main control panel on the driver's door. If it works from the driver's side but not the passenger's, the passenger-side switch is likely faulty. If it fails from both sides, the issue could be the motor, a loose ground wire, or a pinched wire in the door jamb.Check for Sound: Listen closely when you press the button. If you hear a faint clicking, the switch is sending power, but the motor or regulator may be dead. If you hear absolutely nothing, it points to a faulty switch or an electrical fault."
Either way.... would take it back to dealer to check it out.
Blaine
Midwest
FYI - I took it to the dealer and it had a faulty window switch. Luckily they had one in stock so it was fixed the same day and was covered by the warranty. Frustrating for this to happen, but at least they fixed it.
Blaine
Midwest
Why wait? Go and see what caused the problem, you're still under warranty I hope.
I hate taking the car in, it happened two weeks before I need an oil change so I decided to hit two birds with one stone. It was a faulty window switch and they replaced the switch and changed the oil during the same visit. It was covered under the warranty.
