Took advantage of the high 40s and got into teardown.
Brackets here!
He's also on Etsy but I went direct.
The brackets are super sturdy and the provided stainless hardware fit will. Received a .PDF of the instructions from Justin (JJC_LLC) when I ordered with a tool list and photos. It mentions needing a 15mm wrench but I found a 13mm was likely what he meant. The hardware provided was 13mm. Didn't encounter any 15s. Everything else was spot on. The brackets passed right through the grill first try. I did a final lining up of the brackets before refitting the bumper/grill assembly. Needed to make em even.
The Hellas were a straight Amazon buy and included all stainless hardware as well. The bottom carriage bolts are a bit too long and I'll address getting shorter ones later.
I'm not fully on board with the look of LED light diodes so they'll stay covered unless in use. I also sprung for the amber lens covers for foggy days and for a change of look.
Only ran the wiring to the lamps and in the engine bay. I'll get into the final routing into the cabin later on.
I'm into the overall look and fit.
I'll probably post again later once the final setup is done.
Cheers.
Brackets here!
Cheers.
